peirek
Sep 30, 2013Explorer
Yeknomssarb wrote:opnspaces wrote:
Unfortunately you're eventually going to have to find some way to open it up and look. I know I have let my awning slap up repeatedly without damage. But that doesn't mean that yours wasn't damaged by the same thing.
When you push it in, does it feel like just thin wood and then stops when it is flat? If so it might just the the paneling warped away from the frame. If that is the case you might be able to just drive a screw into the bulge and secure it to the stud again.
Yeah I definitely plan to open it up and have a look soon. Like I said before it feels pretty tough when I push it in, I have to give a good 2 handed push to get it to go flat. Then it just pops back out after I let it go. I may be able to just screw it down, but I would feel more comfortable to take a look on the inside before I do that.
I am new to campers and am not entirely sure what something like that should feel like when I try to push it back in place, haha. Also, I am really not sure what the best way to open it up would be. I don't really want to wreck anything else.
Anyone have any tips?
My .02. If it was caused from a leak it would likely feel spongy and the paper would likely pull away from the thin plywood. Especially after pushing it back in. I would not cut it open to check it out. Repairing that cleanly would be difficult. I would await a good rain storm and check for moisture. If no moisture, I would push it in and attach with small staples. I assume a wooden framed trailer?
44,056 PostsLatest Activity: Nov 19, 2013
