BradW wrote:
larkyblast wrote:
The tongue weight on my biggest trailer as we load it would be 800-1000lbs. Loaded it will be 4000 - 6000lbs depending on trip(3000 empty).
This will be a problem.
1,000 lb tongue weight
long hitch extension
8' floor length hardside truck camper
srw truck
short bed truck
I would think long and hard before going down that road.
Good Luck,
bradw
Thanks Brad, I appreciate this.
This is the main attraction to me to the northstar liberty, the 7' floor length. The main drawback of course is the 13 hour drive to buy it sight unseen.
I thought about it a lot last night and if I get the bigger camper, I will give up on towing my bigger trailer at the same time. I think I'd still be fine towing our smaller trailer since I can move it by hand, tongue weight is probably 50lbs.
AS luck would have it though, a dealer in my city just got the Cirrus 820 and 720 in stock!! I can't believe this. Now I can go see both units and decide on the 720 or the Northstar. I was only considering the much heavier 820 because I could not find a 720 closer than Utah. I am leaning to northstar but the dollar just went down again so it's becoming more and more expensive.
Brad what do you think about the 8' camper but with a camper that is 1000 lbs lighter? The Cirrus 720 is supposed to be 2600lbs loaded (same weight as the northstar, just a foot longer), so even with my bigger trailer might be ok.
Going to look at both Cirrus this weekend!
