I've got a 2012 F250 CC 4x4 and I want to put air bags to assist with leveling my truck when loaded. What bags would you recommend, and would you get a compressor with them?
I put Air-Lift Super Springs on my old 97. The boy still has it. They must be at least 12 yrs old and never a problem. I took a load leveler compressor from a old Buick and mounted it in the right rear wheel well, nasty location, it still works. A couple of flow control valves and gauges, a check valve and a regulator. Being able to adjust on the move is the only way to go, lets you fine tune the ride.
