- bikendanExplorerfor you non-hybrid owners, the second pic is for the bunk fan/light combo that nearly all hybrids come with.
there are one above each bunk end and you hang the fan/light on the shepherd's pole. - WavespriteExplorer IIThe second picture is the jack for the bunk end fans....
- PapPappyExplorerObviously, the first picture is of a devining rod, used to find water at a campground. You put one handle in each hand, walk around the RV, until you see a spigot near the power box, and you have found your water:B
I think it could also be used for a sewage tank dolly.....but that is just a guess:B
Second picture looks like a headphone jack....maybe they have it set up for folks that want to listen to music when they go to bed, but don't want to disturb the other folks in the camper, or the CG.? - PadlinExplorer
pookiebear38 wrote:
The plug is for 12v bunk fans. They hang off of the bar over the bed.
+1 - epetersExplorerThe jacks are for the portable fan/light units that can clip onto the poles that hold up the bed ends.
See an example here. - pookiebear38ExplorerThe plug is for 12v bunk fans. They hang off of the bar over the bed.
- obgrahamExplorerHeadphone jack?
- Second_ChanceExplorer IIThe connector is not an "RCA" connector - it is a phone jack - probably 1/4". Being located near the bunks, could it be a headphone outlet for the stereo? Phone plugs and jacks are not usually used for low-level inputs - only for speaker-level outputs.
- darlingtontrioExplorerThere is a radio, it is a JVC in dash radio installed. When I look inside, it looks like threaded inline connector, with nothing in the middle. There is one at the front and one at the back. Boh are right in front of the bunks.
- donn0128Explorer IIFirst is a handle for a portable waste tank.
Second one looks like an RCA jack for something? Do you have radio with aux inputs?
44,027 PostsLatest Activity: Mar 04, 2025
