MarkTwain's avatar
MarkTwain
What brand and power size of generator do I need ?
I have a Lance 20' TT and want a generator that will run both my AC and Microwave at the same time????
    So you don't want to shut off the AC for a few minutes when you are using the microwave? You could save some big $$.
  • drsteve wrote:
    Might be easier to shut the air off for a minute or two while the microwave is in use. That way a single EU2000 or equivalent will do the trick, in conjunction with a soft start kit for your AC.
    I tried that with a previous TC. Would not run the AC.
  • Might be easier to shut the air off for a minute or two while the microwave is in use. That way a single EU2000 or equivalent will do the trick, in conjunction with a soft start kit for your AC.
  • Yeah, I don't think my Yamaha ef3000iseb will run both. The dual parallel linked generators will and the Hondas can be set up to run off of a larger fuel tank. Or you are looking at a 4000 watt generator. Will you need the thing to be quiet? If noise isn't an issue, a 4000 watt or bigger construction style generator will do the trick.
  • 2 Honda 2000's (or similar) in parallel should do the trick. I have a Honda eu3000 and it will run the AC or the microwave but doesn't like both at the same time.
