- JJBIRISHExplorer
MM49 wrote:
JJBIRISH wrote:
Talk is cheap on the internet. Yours is cheaper than most. I'll trust my assessment of structural design of my travel trailer frame. The frame of a travel trailer is one part of a system. The floor, walls and roof all add or subtract to the strength of the frame. The processing and the shipment of frame also have lots to do with quality of the final product. Sorry about the problems that you have had, but I doubt you even understand the root cause of the issues.MM49 wrote:
I was fixing the water tank support on my Sunnybrook and noticed it was a Dexter frame. I am very impressed with the design and manufacturing. Every suspension point is reinforced with a well designed plate. The floor trust use round rod in cross pattern simular to comercial buildings. The I beams are a light weight RV design, not and assembled beam. I expect good performance for this unit.
MM49
One man’s experience with Sunnybrook and Dexter frames…
Fixing the water tank supports seems to be a popular pastime on the Sunnybrook trailer…
also its the weak Dexter frame that allows too much flex in the trailer causing things like… falling water tanks, plywood becoming ripped loose from the roof trusses, siding buckling and cracking above the door and in the same area on the opposite side… then more importantly there were the unexplained sticking doors that needed the jaws of life to get open, or just wait a half hour and it would open like nothing was wrong, to the annual door replacement because they were bent too bad to reinstall… all caused by the weakness in the impressive looking Dexter frame…
MM49
First you can not intimidate me with your cheap talk cheap shot, on the internet or anywhere else…
I sorry but I understand very well the root cause of the issues… the problem is that Sunnybrook didn’t have a good understanding of the root problem… in 4 attempts to cure the problem at the factory they failed… not for not trying… but then they tried to deny ever hearing of the problems they had years after I dumped mine…
After spending many weeks at the plant and them spending thousands of dollars while the siding was stripped and replaced annually, 3 doors replaced at the factory that were too bad to reinstall, replacing a fresh water tank that fell out on the highway. Another trip to the factory to have 2 sheets of ruined plywood on the roof replaced… seeing others at the plant for the same and similar problems each time(when they did very few on site repairs there), the many and continual post here about cracking and the buckling of siding above the door and near the roof line, and seeing others in CG and rest stops and fuel stops with signs of similar things, I think I know more than enough about it…
Just some post made on RV.net alone not counting dozens of reports on Sunnybrook having problems with over flexing frames for many years…
maybe something to look out for, is some of these units developed a crack in the siding above the door frame. It's supposedly a door frame support problem caused by flex. I know of another 298 BH here in town which cracked just like ours '08 that we bought new in late '07
I just posted on another thread that I am taking mine to the factory in April to have the cracked siding repaired/replaced '08 that we bought in early '09.
How does this happen? I would not have believed that aluminum siding would tear like that. It is above the hinge side of the door, and it is under the rolled up awning, Trailer is a '95 Sunnybrook. - MM49Explorer
MM49
MM49 - myredracerExplorer II
filrupmark wrote:
Everybody thinks Lippert frames are bad. The fact of the matter is that Lippert builds frames to the manufacturers specs. Some engineers are good and some are stupid. Hope you dont purchase a trailer that had a stupid tightwad engineer.
I agree, but how can Lippert let the same super-flexible 3-piece fabricated I-beam frames used on a number of ultra-lites out the door? If the customers ask for carp, they build carp? What JJBirish describes below can and does happen to these frames too, and they're still building them. Maybe until you've had one, you'll never know what can happen. Lippert can and does build some decent frames but they aren't on units that should have them. A lot of it is about saving a few miserable $$ and a few miserable pounds.
Jayco is using the BAL Ultraframe on some of their TTs like the Whitehawk. Nice looking frame. - JJBIRISHExplorer
MM49
also its the weak Dexter frame that allows too much flex in the trailer causing things like… falling water tanks, plywood becoming ripped loose from the roof trusses, siding buckling and cracking above the door and in the same area on the opposite side… then more importantly there were the unexplained sticking doors that needed the jaws of life to get open, or just wait a half hour and it would open like nothing was wrong, to the annual door replacement because they were bent too bad to reinstall… all caused by the weakness in the impressive looking Dexter frame… - filrupmarkExplorerEverybody thinks Lippert frames are bad. The fact of the matter is that Lippert builds frames to the manufacturers specs. Some engineers are good and some are stupid. Hope you dont purchase a trailer that had a stupid tightwad engineer.
- MM49Explorer
coolbreeze01 wrote:
MM49 wrote:
The connection is the "Dexter" frame.
MM49
MM49
What about Jayco? - JEBarExplorerlike many companies, Lippert produces various levels of components .... after they took over Dexter, Jayco has used Lippert frames but there is major difference .... the frames they buy have to meet design and component specs provided by Jayco .... they are not off the shelf frames .... so long as they provide Jayco with frames that meet the Jayco specs, there shouldn't be a problem .... if/when they should drop the quality, Jayco has a history of building a facility in which to produce their own components
Jim - Todd_GExplorerThese are the decals on my 2014 264BH. Smaller decal is on the inside left a-frame under the propane tanks; larger decal is on the outside right frame rail near the front.
- HuntindogExplorerI read the Lippert bashing as well.
But, I am on my 3rd TT and the first one with a Lippert frame. It is by far the best one. I have had to do some welding on the first two, one of which was a Dexter. (2001) This one has been perfect. And the workmanship looks first rate.
Some say that the trouble is that the manufcturers spec the frames. That very well could be. - thomasmnileExplorer
Jayco23FB wrote:
Does anyone know what brand of frame is under my 2010 Jayco G2 23FB?
I keep here concerns about Lippert frames......just wondering.
Thanks
Got your trailer's VIN number? If so, call Jayco customer service, they should be able to tell you anything you want to know about your trailer.
44,046 PostsLatest Activity: Aug 01, 2025
