Turtle n Peeps wrote:
Cold air is not going to do anything for this engine. Save the money on the thermal wrap for a good intercooler or tuner. It won't do anything either. #3 The crank sensor can be problematic. (again, this can be fixed)...get a new spare crank sensor. It tells the puter what position the crank and cam is in. Ford dealer. Sorry, this advice was for an auto. If you have a manual you are in much better shape.
If you get a tuner and an intercooler it will wake this truck up. And as said above you need to get the intercooler to keep the charge cool. And you need to get a tuner to give it more fuel. IOW's you need both.
I've already got the thermal wrap (it was inexpensive).
The previous owner gave me the tuner & showed me how to use it. It's got 2 tow modes apparently.
I'll start researching intercoolers. Thanks again for the advice.
