I think I figured it out!
Data stickers &
Understanding ratingsSo, as I understand these explanations, the trailer's GVWR is not the same as the trailer's UVW.
The trailer's GVWR is the maximum weight the trailer's axles can handle: weight of the trailer + weight of (potentially) a lot of cargo is the maximum weight the trailer can safely have on its own axles.
The more important numbers to look at on the trailer, in order to know if the truck can tow it, is the Unloaded Vehicle Weight (UVW) & the Cargo Carrying Capacity (CCC). We need to add the the UVW + what we think our CCC's going to be to know if we can to it or not. GVWR means nothing for towing.
Example:
UVW of trailer: 7,000 lbs
CCC of trailer: 2,000 lbs
GVWR of trailer: 14,000 lbs
GVWR of truck: 10,000 lbs according to people I trust & 13,800 according to manufacturer
Since UVW + CCC = 9,000 lbs we are under 10,000 lbs. Conclusion: we can safely tow it!
In this case, if the CCC is 3,001 lbs + UVW = 10,001 probably unsafe for my truck to tow.
In this case, if the CCC is 7,001 lbs + UVW = 14,001 probably unsafe for the trailer to carry this much cargo.
This calculation does not take into account GAWR (Gross Axle Weight Rating) of truck. Which is just as important to calculate. The truck's Front Axle Weight Rating (FAWR) is 4,600 lb & it's Rear Axle Weight Rating (GAWR) is 6,084 lb.
The trailer will have 20-25% of its weight on the truck's axles (front & rear, but mostly rear).
In this case if our UVW + CCC = 9,000 lbs the Hitch Pin / Tongue Weight (the weight the truck's axles can hold with a fully loaded trailer pushing down on the 5th wheel hitch) is 1,800-2,250 lbs. The truck's axles can easily take it!
