dieseldan723's avatar
dieseldan723
What can I tow with a Tundra DC?
In the last 10 years I had three diffrent Duramax trucks - which are AWESOME tow vehicles. I sold my 5er's and the toy hauler, so we are empty trailer nesters right now. :)
We recently purchased a 2011 Toyota Tundra 4X4 with the 5.7l. It does have airbags already installed (PO had a camper on it).
My question: What is a good TT that DW and I could purchase that wouldn't be too heavy? Two of my previous trucks were out-trailered for sure so I don't want to get into that position again.
We prefer slideouts and a king bed (queen would also work). I look forward to the thoughts of the current experts!
Dan
  • Stick to around 6k dry and you should be pleased.
  • A look at your cargo handling label on the front driver's side door pillar will be a good first step. With smaller vehicles, the weight put on the vehicle, the trailer's tongue weight, is the most important. That weight, along with any passenger and cargo weight, will describe the total capacity of the vehicle while towing.
    There may also be weight limits on the vehicle's towing capacity (weight on the rear end), intrinsic limits due to comfort and towability, or other reasons not to exceed a certain amount of weight. Your floorplan choices are probably going to push the limit of the Tundra's towing configuration but there are many happy Tundra users that haul travel trailers. I would expect that trailers with a weight of around 5000 lbs, unloaded, would be towable with a Tundra.
    Here is a specifications table that lists the weight handling of the Tundra's different models: Toyota Tundra link
    You may also wish to check Toyota Tundra Forums where really applicable towing methods are discussed. Towing a large sail down the road is sometimes beyond just the weight numbers.
