Gdetrailer wrote:
Lantley wrote:
Gdetrailer wrote:
For the record.. The SUBFLOOR thickness and type of material IS the problem, not the construction method.
Yes, some manufacturers skimp on the subfloor thickness and type of material on some models and that IS the problem.
It's not simply a subfloor problem. Simply replacing plywood is doable.
However it's replacing the sandwich...multiple layers that complicate the repair.
Nope, wrong you are.
Here is a illustration of the "sandwich floor".
Click For Full-Size Image.
That is taken from my 1984 brochure.
Please kindly note the critical area that the red arrow is pointing to.
That is the subfloor and that IS where the problem begins at.
I'm glad you feel the red arrow points to the critical area. But you need a few more arrows. Often the problem is the joist are over spanned. The trailers are built on 24" centers which exceeds the structral integrity of the panels. Another issue is that the foam get weak and flexes been the 2 layers of plywood. Much in the way all plywood is not created equal, All foam is not created equal. Once that flexing begins the soft spot spreads. You end of with weak areas between the joist.
Is it the plywood that fails or is it the foam. I imagine both have issues because soft floors is a very comon issue.
But the biggest is is the repair is not easy.
Its not a matter of simply replacing the plywood because often the foam is compromised as well. Now you get into replacing the entire sandwich while trying to maintain the original thickness.
The sandwhich panel is beneath all the interior wall and furniture.
The panels are most likely under the exterior walls as well.
The other issue is trying to properly support the sandwhich with additional joist. The 2x2 wood framing at the end of the panels are also prone to failure who frames a floor with 2x2 studs?
THe bottom line is the panels fail be it the plywood, the foam or the framing. Leaving unsuspecting owners with soft spots.
This is a known issue that doesn't seem to be getting any better or this thread would not exist.
Interestingly your photo is from a 1984 brochure, you would hope they would have this issue resolved by now. But soft floors are still a common and reccuring topic.
