txdxrider's avatar
txdxrider
What could I be missing?
Hi all - new member - have been researching a LOT lately and just looking for some verification..
We are looking into TT fulltime (for a year or so) to give the kids a different view of NA starting spring 15...
There will be 5 in the TV self, DW, and three boys 14 and downward, and a dog - most (if not all) gear will be in the TT.
TV is going to be a 2009 Suburban Z71 4WD - 66K miles 5.3l with 3.42 gears - 6-speed auto - NO HD Tow package - est trailer weight 7900# per MSRP and stickers.
Stock I have pulled a 4300# full size Bronco on a 2K# trailer - but only for a few hours - looking at a 27ft Heartland 24BHS - dry weight @5500# - so loaded should be 6500# to 6800#....
Current mods to do to TV - steel brake lines, K9000 adj shocks, Trans Cooler, Trailer Brake controller, upgrade the OEM hitch, load equilizer - at the same time do a fresh trans flush, brake flush, pads (about due anyway)-so starting out up-to-date.
Trying to keep the current TV instead of moving to a P/U since the room in the burb makes traveling so much easier - but havent ruled out an older excursion or 2500burb - would rather not change the TV
Am I being too optomistic on what the burb will handle, or should I look at a TT closer to 4500# dry..
Thank you in advance...
