Durb
Jul 29, 2018Explorer
If you max out your axle ratings and your tongue weight is 15% your total trailer weight will be 6,341#. I towed a 25 ft. trailer at 6,000# with my 2008.5 Titan and it did OK, plenty of power. I used a Reese SC hitch and never had any sway. It did squat about 3" in the rear with the trailer hooked up which I brought to within 1" with the hitch bars. I installed air bags which I ran at 40 psi to bring it level. I had to really wind it up to maintain speed on grades but it did it without complaint.
Like you, I felt like it wasn't going to last long. The brakes were suspect and the rear diff was the size of a soccer ball with an axle ratio under 3 if I recall. Mileage was pretty bad averaging a little over 9 for each trip. Mine was 4WD Pro4X and towing was real tough on the OEM tires as they were shot at 30k. I was a rookie and can't say if I was within the truck's numbers. I upgraded/downgraded to an older RAM.
44,026 PostsLatest Activity: Jan 26, 2024
