dodge guy wrote:
Terryallan wrote:
dockmasterdave wrote:
For a travel trailer, reduce the manufacturer's rating by at least 1/3.
I've recently discovered how much wind drag isn't figured into those numbers. I'd guess a TT about 8,000 would be a comfortable tow.
Ford figures their tow capacities with a 60 SQ foot front wall..
Is that the entire front surface, or just what is protruding up around the cab?
This would be the entire face showing to the wind in front of you, truck, trailer etc. If the trailer falls with in the frontal area of the TV, then generally speaking, the trailer does not add a lot of resistance per say. If the trailer face is wider, or taller than the truck, that is the area to be used for frontal area.
An older setups I used to have, one was pulling an equipment trailer total 15K gcw, with 70 sq ft of frontal area, needed about 105hp to motor down the freeway at 60 mph. Change the frontal area to my TT ie 90 sq ft, I needed around 135hp to go 60 mph. Same 135hp as a 25K rig with 70sq ft of frontal.
In 92 when I bought my TT, in the rv dealers showroom was a tow rating poster for Ford trucks. You got the max tow rating of 10K at the time IF you kept the FA to under 80 sqft, If 81-100, it was deducted 2500 lbs to 7500, 101-120 was down to 5K lbs total trailer wt. For the Aerostar van and Ranger pickup, max was 5000 lbs to 60 sq ft, 61-70 reduced 1000lbs, and 71-80 reduced 2000 lbs, over 80 or 120 for these rigs was not recomended you tow a trailer with your Ford truck.
The new specs do not include this kind of deduction, nor do you get a deduction if you need to start on a grade steeper than 12%. My sister has an 18% grade in front of her house, my drive way in an older home was just over 20, a client had one that was 33%! One can not pull those hills at max gcwr without literally stalling your rig out, blowing up a trans etc..........
The tow ratings need to include deductions for this type of issue.
A fellow that I have not seen post in awhile, delivers RV trailers. WORST mpg is a sts TT with aluminum siding, then a fiberglass version, then a front bedroom slide 5W, then an aluminum sided non front bedroom slide 5W, smooth fiberglass non bedroom slide 5W, best was an airstream, or at least on par with the fiberglss sided mid sized 5W.
Marty
