wintersun wrote:
If the truck is squatting with the weight of the camper in the bed you need something to help the main leaf packs at the year. That means adding a leaf to the pack or adding a pair of SuperSprings. I went the SuperSprings route and bought the ones that come with a pair of leaves for each side and paid $445 and spent an hour installing them. I got the four leaf set and took out the two inner leaves, which was easy to do and then installed the outer leaves.
I did this as the two sets with two leaves was only $45 more than pair of the single leaf and this way if the single leaf on each side was not enough I only needed to reinstall the Supersprings with the additional leaf on each side.
Ride is pretty much stock with the camper off the truck and handling is great with a 4,000 lb. camper in the bed. Nothing to wear out or need to adjust.
I did the same thing. The single leaf was enough so I removed the second leaf. I am very happy with my SSs.
