rutzbeck's avatar
rutzbeck
What else should I use?
I have replace the air bags on my truck 3 times. This last time they only lasted 8 months. I have a 3500 dually Chev with a 1999 2500 10.5 bigfoot on it. I'm pretty sure I blew it out on a frost heave that I didn't see well enough in advance. I put the bags on to even out the bed from side to side and to keep it from squatting so much in the rear that the mud flags would drag. I do not want to spend anymore money on air bags. Where should I go from here?
  • There has to be a reason you are blowing airbags out. It's not even remotely normal to blow out bags!
    The Air-Lift system airbags we put on our 1993 Chevy 2500 ext cab LB 4X4 in 1993 are still working fine today with 20 years use and over 300,000 miles on them. We put the first 128,000 miles on the truck with 2 different Lance TC's on it. The truck was only used for RVing when we had it. We then sold it to an asparagus farmer friend of ours who hauls heavy loads of crops, fertilizer, equipment, etc year around and the truck now has way over 300,000 still with the same airbags working just fine as is the onboard compressor with dual controls in the cab. We see the truck a lot every year as we own property next door to his farm and talk to the owner several time each year.
    Our present 2004.5 Chevy 2500HD D/A CC LB 4X4 truch has close to 150,000 miles on it today and still has the same Air-Lift bags on that were installed in May 2004 and they work fine. Truck carries the 11'4" Lance totally optioned out TC that weighs over 4,000 lbs load to travel. Never even had any bags leak either.
    On the 1993, I inflated 40-50 psi as that leveled it and rode the best. It went to Alaska from Michigan twice with the longest trip being 13,137 miles and yes, we know frost heaves. On the 2004.5 D/A with the big Lance on I inflate the bags to 65-70 psi as that seems to be the best. Approx 52,000 miles with the big Lance on the truck and the rest of the miles were with either our previous 9.5' Lance or our 29' Carriage Carrilite 5th wheel as this truck has also only been used for RVing. We have other vehicles.
    Somethings not right and causing your bags to fail!
