JIMNLIN
Aug 24, 2013Explorer III
bikerdib wrote:
All I can say is I'm very happy with the factory system on my '13 Ram.
FYI you don't have a exhaust brake on your 6.7 Cummins. The 6.7 engine uses the Holset turbo VGT with a sliding nozzle system that acts like a exhaust brake. This system isn't used or can it be adapted to the 5.9 engine.
The OP has a 5.9 Cummins and it requires a actual "exhaust brake".
I had the Jacobs exhaust brake installed by my Dodge dealer as part of the package deal when I bought my current '03 Dodge. It operates from vacuum which requires a mechanical vacuum pump to be added to a much longer serpentine belt. Works great and no issues so far with 220k on truck.
If I had a 5.9 I would get the Pacbrake for two reasons.
1st.... it works from a electric air pump. Add a tank and air pressure can be used for other purposes.
2. All EB have the same max exhaust braking power at max rpm. However due to the way the Pac works it has a bit more braking under 2000 rpm.
I had a BD exhaust brake on a '96 DRW Cummins with the NV4500 tranny. No issues with it.
