- ib516Explorer III had one. Go for the 4.10s. The gap between 1st and 2nd is big and the 4.10s dull that a bit. Also, the GCWR and max tow rating increase 3000# when you go to 4.10 from the 3.73.
The 3.73s will easily tow your 7000# load, but the 4.10s will allow for a bigger load if you upgrade RVs. - LwiddisExplorer IIWith today’s transmissions, the 3.73 is fine. I’m happy at 3.43 and 5200 pounds of TT.
- MFLNomad IIIt depends, if mostly for towing, the 4.10 is best choice. The 3.73 will work for that size trailer, and maybe get slightly better mileage, in every day non towing. If you decide to get a bigger trailer at some point, you may wish you'd have gotten 4.10.
Jerry - 2Rad4UExplorer III4.10 without a doubt
- donn0128Explorer II3.73 is fine unless your pulling a LOT in the mountains. Then I would only consider 4.10 is you like to run really fast.
