mkletka
Jul 23, 2016Explorer
Thanks for the help. I think that I have it figured out. I do believe that I need new batteries. There is enough of a charge to start the generator and run the fridge but don't know for how long. I did discover a toggle switch near the bottom of the generator. It's says 25 amp breaker. When I flipped the switch the generator switched the power over to the camper. The AC works and all the outlets also work while running on the generator only and disconnected from shore power. I've never tried to run this camper only on the generator. It's a 1998 Alpenlite and the generator only has 10 hours on it. I would have never found the switch on the generator as it's down low and in the dark and is also dark in color.
One question on the batteries. They is currently a group 95 and a 92 installed. Should they both be the same size? Best to install the same size and as large a size that will physically fit in the space?
I really enjoy solving these problems with all the input from all the experts.
