- whizbangExplorer IIThe rubber mat.
It drastically increases friction. Tie downs don't hurt either. - bobndotExplorer IIIUse 4 truck camper bolts:
- CAJWExplorer
- steve68steveExplorerAnd funny enough, they say to not tie down your camper too tight. Tie downs even have built-in springs...
... so the camper can 'bounce' in the truck bed! - joe_b_Explorer IIAs mentioned weight and friction do most of the work in my opinion. The tie downs are to keep the movement from ever starting. Most TCers use some sort of rubber mat between the TC bottom and the truck bed to add a bit more non-slip to the rig.
One other type of system for tie downs that also replaces having to have a jack system is the www.stablelift.com Several of the forum members have such a set up and speak highly of it. It actually clamps the TC to the truck bed.
For the most part, on a trip when the camper settles in and gets squared up to the front of the bed or whatever you have it up against, a spacer, etc normally there is very little movement on the rest of the trip. This past summer I had to make some small adjustments on my tie downs about half a day into the trip and for the next two months they didn't have to be touched. Many times you can catch a sale on any of the major brands from many dealers, or find them on some free list such as Craigs. Some of the parts are truck specific, so you may have to look a bit to find a good used set as they seem to last forever. LOL - Super_DaveExplorer II
iwon415 wrote:
portscanner wrote:
Romantic attraction.
Love.
Gravity.
Dumb luck.
Sometimes bolts.
Other times tie downs.
Had to laugh at this! I agree sometimes it feels like dumb luck. Hard to believe those four little lengths of metal can hold 5000 lbs in a bed of a truck sometimes!
TimH
I guess I'm on the other end of amazed as I find it funny that 5,000 lbs needs to be, "held down". - Led_67Explorer
Gripnriprod wrote:
No such thing as a dumb question!
Actually the only dumb question is the one that is never asked.
The tie down system for a TC has come a long way yet retains mostly the basics when you consider how they work. From the days when a TC was simply bolted to the floor of the truck bed and maybe somtimes they would bolt into the frame rails, The Happijack system that utilizes the truck bed body, The Torklift system that utilizes brakets that are attached to the frme of the vehicle, Even the old stakepocket tiedown system that is part of the truck bed yes the systems are all different yet the same. - iwon415Explorer
Love.
Gravity.
Dumb luck.
Sometimes bolts.
TimH - portscannerExplorerRomantic attraction.
Love.
Gravity.
Dumb luck.
Sometimes bolts.
Other times tie downs. - RoyBExplorer IIThis is what the FAST GUN TIE DOWNS look like...
Roy Ken
44,056 PostsLatest Activity: May 04, 2014
