Huntindog
Oct 10, 2013Explorer
ScottG wrote:Not all axles are the same. Some have a crush sleeve, and some don't. Make sure you know what procedure is recommended for your axle.
You can do as Don describes but do your homework first so you know exactly what your doing.
The nut needs to be marked before removal and then re-installed by screwing it in the EXACT same number of turns and then lining up the markings you made during disassemble. If this isn't done correctly the bearing preload will be altered and it will fail.
Here is a great write-up of the process: Diff seal replacement
Scott
