wsc7050's avatar
wsc7050
What is the "cold" temperature for tire inflation?
Hello quick question. My trailer tires instruct me to use 65 psi when cold. Well some days I start in the 30's and some days in the 70's. And for argument sake, let's say both of those days end in the 90's. I know from using my tire temp and pressure monitor that if I put 65 psi in at 30 degrees and ran it to 90 degrees it would be different than if I put it in at 70 degrees and then ran it to 90 degrees. So should I be aiming for 65 psi for the temp I would spend most of the day towing at, or?
Thanks in advance!
  • a cold tire is one that has been sitting, say over night or several hours with out movement
  • Always, always, always use cold temperature stated on the side of your tire, Check an inflate the tires when they are cold, never, never deflate a hot tire to a cold temperature.
    If you think a tire is going flat and you check it an it reads low, then inflate the tire to match the already warm/hot other tires, then check that tire again the next time you stop again, if it's low again then seek out a tire shop to get tire repaired or change to your spare if you have one ...
    Only add air if the tire is going flat, temps will very on different road surfaces, cement, asphalt, hot and cold ambient temperatures. They will always gain air when hot and loose when cold unless they a filled with nitrogen an then they will still gain some or loose some but the temperature of the tire will however run cooler overall ...
    I always check my tire pressure 1st thing in the morning before starting out, i check the temperatures of the tires and axle hubs during the day when I stop to make sure they are not overly hot to the touch, some people use lazier gauges to do this same thing.
    Safe travels
