wsc7050
Jun 17, 2017Explorer
What is the "cold" temperature for tire inflation?
Hello quick question. My trailer tires instruct me to use 65 psi when cold. Well some days I start in the 30's and some days in the 70's. And for argument sake, let's say both of those days end in the 90's. I know from using my tire temp and pressure monitor that if I put 65 psi in at 30 degrees and ran it to 90 degrees it would be different than if I put it in at 70 degrees and then ran it to 90 degrees. So should I be aiming for 65 psi for the temp I would spend most of the day towing at, or?
Thanks in advance!
Thanks in advance!
