Sparkndeb wrote:
So, after months of looking for a TT for my 2013 Tacoma to safely tow< I'm still confused about the GVWR. On some models the dry weight is say 3155 lbs with the gvwr at 5890lbs. So, I can put 2735lbs in the trailer? Who carries that kind of weight? What am I missing here? I need my gvwr to be around 4500lbs or so (I think). Help!
I think you're missing the fact that you can ignore the TT's GVWR unless you actually plan to load it to that value, and most people do not.
Your TV doesn't care how much the TT
can weigh. It only cares how much the TT
does weigh.
The TT's GVWR has nothing to do with your TV's towing or carrying capacity.
The numbers you need to be concerned about are the TT's loaded tongue weight and the TT's loaded GVW which is determined by the TT's dry weight plus the weight of any cargo that is added to the trailer.
As others have pointed out, a TT's loaded GVW typically is equal to somewhere around the dry weight plus 1000#.
However, some people add only about 500# of stuff and others might load 1500#.
The maximum allowable weight for your TT might be directly limited by your TV's GCWR (posted on a door pillar sticker), or it might be indirectly limited due to a tongue weight limit.
The tongue weight might be limited by either the receiver's tongue weight limit or the TV's Load Carrying Capacity.
The maximum amount of passenger and cargo weight your vehicle can carry is the Load Carrying Capacity indicated on the label(s) on the driver’s doorjamb.
The best basis for determining how much your TV can tow and carry is a measurement of the loaded-for-camping weight of your TV -- including occupants, cargo, and weight of the weight distribution hitch.
If you cannot take your loaded TV to a scales, you can get a reasonable estimate of maximum allowable tongue weight by subtracting the estimated weight of passengers, cargo (including items added after delivery), and WDH from the TV's Load Carrying Capacity.
If the remainder is less that the Maximum Tongue Weight listed on the receiver, use the remainder. Otherwise use the value listed on the receiver.
To get an estimate of maximum allowable trailer weight, multiply the maximum allowable tongue weight by 8.
If you know the loaded-for-camping weight of the TV, subtract that value from the TV's GCWR (listed in the Owner's Manual).
The remainder is the maximum allowable weight your loaded TV can tow.
If you don't know the TV's loaded weight, subtract the estimated weight of occupants, cargo, and WDH, from the Maximum Towing Weight listed in the manual. The remainder is an estimate of the maximum allowable towing weight your TV can tow.
As an example, let's assume:
TV's Load Carrying Capacity (payload) = 1400#
Weight of occupants, cargo, and WDH = 900#
Maximum Towing Weight = 6500#
Receiver's TW rating = 650#
Maximum allowable TW, based on payload, would be 1400-900 = 500#.
Corresponding maximum trailer weight would be about 4000#.
Maximum allowable TT weight, based on Max Tow Weight, would be 6500-900 = 5600#.
This value is greater than the estimated Max Tow Weight based on payload, so the 4000# value is the limit.
If the "dry weight" value for a prospective TT comes from the sticker on the outside of the TT, it should be a reasonably accurate value. If it comes from a brochure, you might need to add 200-300#.
Subtracting the proper value of "dry weight" from 4000# gives you the amount of stuff you could add to the TT for these example numbers.
Remember, the example maximum of 4000# is the TT's loaded GVW -- not to be confused with the TT's GVWR.
It makes no difference what the GVWR is, as long as you don't exceed it.
Ron
