ShinerBock wrote:
Because GM is not in a "best in class" pissing match like Ram and Ford are and I commend them for it. Just because your truck can tow 30k at the minimum 35 mph using J2807 doesn't mean that is what you have to rate your truck for. Using a higher minimum speed limit like 55 mph will make your tow rating lower than the J2807 standard, but it is a more reasonable speed at which most would prefer to tow and many will respect that. It is only the fan boys that are concerned with "best in class" and care about the highest tow ratings possible even though they themselves would never tow that much. This is coming from a Ram owner who also prefers a Ford over GM.
GM uses the highest tie ratings for all of their other ratings. their gas trucks, 1500’s, 2500’s and srw 3500’s are all right there with ford and ram. doesn’t make sense that they would only choose to under rate their heaviest package, or that they have higher standards. i have owned 5 chevy trucks, one ford and one ram. not trying to start a pissing match, just trying to figure out why they are rated so much lower. they used to be as high as the other two.
iI would rather be using 70% of my trucks ability than 95%. if two silverados were side by side snd were the same price, and one was rated to tow 9,000 lbs more than the other i would choose the more capable truck.
i have been looking at some of these comparison tests, and they are sort of rigged. they are towing a lad of about 22,000. haven’t seen a test towing 31,000 lbs because only two of th trucks could compete. by that logic have a test towing 5000 lbs. most half tons trucks would win a drag race against a dually, and ride better. that doesn’t make them a better towing machine.
i am really just trying to determine what is the limiting factor on the silverado. not saying one is better than the other, don’t care.
