We have a seasonal campsite in upstate NY and also in South Carolina where the RV just sits for months at a time. As a routine, I run the slides in & out about once a month and lube the systems as required twice a year.
The big issue with sitting in one place is the battery(s). If you are plugged into 110v all the time, you need to check the water level about every 3 months or so and topped it off as required. My experience with an RV battery plugged in all the time is that it likely needs replacing about every 5 years or so otherwise the slides may not extend or retract.
