EcoBullet's avatar
EcoBullet
What jack do you use in case of a flat?
So far, in 8,000 miles of towing, I haven't had a flat, but there's always the first time. I'm not sure the jack in my truck would go under the axle of the trailer. What do you carry?
  • mhardin wrote:
    I use one like this:
    I presume you pull the other tire onto this?
  • Thanks to all. What is a trailer aide? Good point about jacking the frame instead of the axle. I found a couple of videos on You-tube showing the method of pulling the other tire on the same side up on blocks. That would probably work well most of the time.
  • I have had a flat, and had no jack, but I used the leveling blocks placed under the OTHER tire on that side, and it picked the flat up high enough to change the flat for the spare.
    I agree a bottle jack should do it, and I have seen a "rocker" device that you place under the axle and pull the rig forward to raise the wheel off the ground.
  • A 8 or 10 ton bottle jack should do it. Make it rises enough to reach the frame on your trailer. Generally, lifting by putting it under the axle is a bad idea and could cause significant damage.
  • I carry a small bottle jack, chocks, a stand, and some lumber.
