Huntindog
Sep 22, 2014Explorer
I consider heated and enclosed tanks and valves as a starting point. That's what my TT came with.
It was OK till about 6 degrees. Then pipes started freezing.
I have since added heat tape and insulation to all plumbing, and added another heat vent to the tank area, along with R7 polisonocrate (sp) insulation to the entire under belly, including the frame rails. It should now be good to 40 below. So long as I have gas and propane.
44,066 PostsLatest Activity: May 13, 2026
