CapriRacer wrote:
Words of caution:
1) The tire load tables are MINIMUMS! (or maximums, depending on how you look at them). they are NOT recommendations. So if you use a table, be sure to use MORE pressure than indicated.
2) There is side to side weight variation that has to be taken into account if you weigh the entire axle as a unit. That would be on top of #1 above.
The tables tell you what the tire will carry at a specific weight. NOT minimum. NOT maximum. Just what it is.
Now the GY Tech person I talked to when I went from E to G on my RV said to weigh the axles and add 5psi to the chart.
