old_guy
Dec 25, 2013Explorer
a lot to think about when buying one. the TT frame comes in two sizes 2" and 2 1/4 inch. that is not the important item but something to consider. mainly if you get a 2500 or a 3500 they might have a 2 1/4 diameter tube and if you only have a 2" frame opening, you will have enlarge the hole so it will fit, I had to do that, it's no big deal if you have the right tools. one thing to consider is if you do get the 3500 you can always take it with you if you upsize your TT. unless the new TT already has one . all in all I would get the biggest you can afford as long as it is at least a 2500 or bigger.
44,066 PostsLatest Activity: Mar 14, 2015
