JBarca
Mar 05, 2021Nomad II
way2roll wrote:
Need to get a jack and stands for my new F350 6.7. We have a Harbor freight in town but the largest they have is 3t. Is that big enough? Doubt I'll use it much on the truck actually, more for my Son's Mercedes and Wife's CRV. But if I am going to get a new jack and stands, might as well get them big enough to handle the truck if need be.
Hi,
Not sure what you are doing with the jack stands. There is a weight rating need, and then a stability need.
I looked today at Harbor Freight and seemed to stop selling the 6 ton and the 12 ton stands. Must be that lifts are getting more popular and the call for larger jack stands are not enough for them to sell them anymore.
Point in this, I have 4, 6 ton jack stands and 4, 12 ton jack stands from HF. I have had them for a long time. I go for stability along with weight rating. And how I use them, stability outweighs the weight rating most times.
Last winter I went all through my 2005 F350. Engine, frame rust, all of it. I used the 12 ton stands to reach high enough to get the stand up to the frame and the truck off the ground. See a few pics at the start of the project.
On our big camper, 10,000#, again when I have all 4 wheels off, I will use the 6 ton or the 12 ton, again for stability at the height.
The camper on the 6 ton stands during axle replacement.
The camper when doing frame repair using the 12 ton, I had them by this time.
The 3 ton, will hold 6,000# per pair, just the foot print is small. For what I do with them, the 3 ton stand has too small a foot print for me. It all depends on what you are doing with them at what height.
Hope this helps
John
