theoldwizard1
Jul 10, 2017Explorer II
BlueridgeCoachmen wrote:
I would like to put a 30 amp RV plug on my garage. The service pole is about 80 feet from the garage. I was wondering was size wire I will need to support 30 amp service.
Just to be clear, are you saying that the garage currently has NO POWER ? If this is the case, then you need to install a breaker panel in the garage and the wire should be sized for AT LEAST 60A.
How far is it from the breaker panel to where you are going to place the RV outlet ?
