mark10's avatar
mark10
what to buy - truck wise
so I posted that a truck and TC is in my future. thinking of ford. but when I go onto the ford site and try 'building' my own, the various options are mind boggling. what size bed, what wheelbase, what suspension, etc.
options like what radio I can deal with.
I haven't look around here a lot, but is there some place I can go to which will define all this stuff.
like why a longer wheelbase?
bed I guess would define which TC will fit.
  • I am window -shopping for 2016 F350 dually and with all those listing errors it takes LOONG time.
    Somehow supercabs are not available, so I would have to settle for crew cab.
    Than you can buy base truck for $51k, or King Ranch for $74k.
    Do I really care about moonroof and backup sensors having camper?
    I plan to buy in January/February so hope dealers will stock more truck
    So far in 700 miles radius I located 3 I would consider.
    Have fun searching.
  • Fords come in three different cab sizes and two different bed lengths resulting in six different wheelbases. Although I was very happy with my F250 extended cab short bed, it did limit which truck campers I could purchase. Our Arctic Fox 811 is very well built but we want additional features that a F250 short bed really could not handle well. I have since upgraded the truck to a Ram 5500 with 9' deck that can handle the largest TC or FW RV currently produced - When we bought the F250, we never considered these RV's as possibilities (our wants have changed).
    I would not suggest the F450 pickup over the F350 for TC use since it actually has less payload available. If you need additional capacity look at the Class 4 or 5 chassis cabs as the next step. I don't suggest you run out and buy a Class 5 diesel, but I do suggest figuring out which RV suits you and scale the truck up enough to allow an upgrade in the future without having replace it. Having extra capacity to make changes or select a different RV in the future is much easier than having to replace TV and RV at the same time.
  • For a truck camper you want a long bed and a 3500 series. To get anything less is really really limiting your options. The real question is do you need a dually or not.
    If you're thinking of a 2wd regular cab truck with a gas engine, 2 people, and an 8 or 9 foot camper then a SRW would likely be fine. If you want 4wd, diesel, 4 doors, hauling the kids, with a 11' camper with slides then get a dually if not a 4500 series.
  • A long bed 3500 for sure. You really limit yourself with a short bed. Then you have to decide on a dual rear wheel or maybe a 4500. These rigs are heavy, when you get them loaded for travel. JMHO. Plus don't know if you are buying new but if not there were big improvements at least in the chevy's 2011 on. I think the fords too. JMHO
  • Over build the truck and you will never be sorry. A long bed truck will ultimately give you more options in the long run. Fitting the truck to a TC may or may not hamper your decisions to upgrade TC's in the future. I bought the biggest, heaviest duty truck that I could afford and then went camper shopping.
  • If you are buying new find the TC you like than find the truck that will carry the weight.
  • Need to pick out the TC first. And how many doors you need.
