BillB800si
Sep 13, 2013Explorer
elivi8 wrote:
Can you use the existing wire as a pull wire? Then you could replace it to whatever you need. Ryan
Very good choice Ryan.
Disconnect the cover- then remove the phone connection. Now take that phone wire and securely attach it to the new wire you want. Go outside and start pulling the wire thru the wall of the RV. Once the new wire appears you now have a new wire for your 12 volt needs.
Oh, make sure the new wire can handle the current load you want.
Happy trails,
44,056 PostsLatest Activity: May 04, 2014
