RbertalottoExplorerMar 05, 2020What TPMS should do...Have an option to add temp sensors to the hubs. I wonder is shader valves on the grease caps would send hub temperature using the tire pressure caps?
2oldmanExplorer IIMar 05, 2020My Eeztire system does temperature. I don't understand your second sentence.
Related ContentWhat do you do?How do you do your turkey?do you do thisHOW do I do this?Doing without propane
