RbertalottoExplorerMar 05, 2020What TPMS should do...Have an option to add temp sensors to the hubs. I wonder is shader valves on the grease caps would send hub temperature using the tire pressure caps?
Related ContentWhat do you do?How do you do your turkey?do you do thisHOW do I do this?Doing without propane
