KillerIsMe wrote:
Curious to know my Friend - what don't you like about the outdoor kitchen? I am asking because we are considering a Jayco SLX 242BHSW with that little kitchen under the awning.
Lynnmor wrote:
Just so you know, those wonderful electric awnings are so flimsy that they need rolled up at any signs of bad weather. Then you need to transfer everything inside anyway. I am in the minority here, but I would pay extra for a manual awning like was available years ago.
I'm one who did do that several years ago with our KZ Spree which was originally fitted with an awful Carefree of Colorado power awning that had virtually no tilt and would only suddenly dump water off one end when it got too heavy. :M
I replaced it with a manual Dometic 8500 that I could tilt WAY down and which would easily shed water even in the heaviest thunderstorm, allowing us to sit under it or even cook even in the worst weather.
As to that Jayco 242BHSW "outdoor kitchen", it really isn't, at least not compared to outdoor kitchens on many other trailers where it's MUCH larger and has a large hatch door that swings up to create a "roof" of sorts over that area to protect it during inclement weather. With this Jayco "kitchen" you'd want the awning to cover that area, otherwise it would be useless when it's raining. However, if the awning is the type that can't shed rainwater easily then that wouldn't be a solution either.
Personally I see these "outdoor kitchens" as almost useless as you're only duplicating what you already have inside yet will inevitably have to go inside anyway to get something you don't have outside. The fridges in these outside kitchens are just a 120 vac dorm style fridge so it won't be running when you're traveling, will only operate when you have shore power available, and are quite small in capacity anyway. Unfortunately, one of the few trailers we'd consider trading our current Freedom Express 192RBS for - the
Coachmen Freedom Express 231RBDS - does have an outdoor "camp kitchen" which only makes the trailer heavier than it needs to be and causes the bathroom inside to be smaller than it also needs to be ... grrrrr! :R
