BubbaChris
Jul 23, 2014Explorer
westend wrote:
Look on the driver's side door pillar for the Payload weight rating, something like, "weight of passengers and cargo should not exceed..." The payload weight will be the limiting factor for towing, you will run out of payload weight before you hit the GCWR of the Durango.
This is one of the best replies so far. You'll want a minimum of 10% of the trailer's total weight to be on the tongue. So subtract the weight of your family and likely in-Durango cargo and that is the number left for tongue weight.
Probably not much. You'll likely be limited to trailers with a box length around 20 feet or less. Look at the Lance 2185
44,056 PostsLatest Activity: Nov 19, 2013
