plasticmaster's avatar
Nov 16, 2015
What's in between the floor and underside of TT?
I have a 2008 Jayco 28BHS that has formed a leak near the roof/side wall of the camper in the rear bunk bed area of the camper. So far, I can't find the leak, but I've gutted the whole area on the inside, so I know approximately where the water is coming in. I'm using fans and dehumidifier to dry it up. Anyhow, the water came down the inside of the walls and I've stripped everything down to the bare plywood floor. My question is what's under the floor? When I lay on the ground outside the camper and look at the underside, there's a black burlap type material that feels heavy in this area, but doesn't have this heavy feel on other parts of the underside of the camper. Is this wet material that I'm feeling? How do I access what's under the plywood floor? Do I do that from the underside and what all is under there? Also, I resealed everything that protrudes from the roof 5 months ago. The leak is not coming from any of those places. Any ideas where it could be coming from and what to do about moisture under the plywood floor? Thanks.
