- Doug33ExplorerSpeaking of aerodynamics and drag, have you seen the episode of Mythbusters, where they took a car and added a clay layer with round dimples to emulate a golf ball? Compared to a smooth surfaced car, the golf ball dimple car actually got significantly higher gas mileage in their tests.
- WoodGlueExplorer
WoodGlue wrote:
Maybe an CampLite Trailer
CampLite
Which is all aluminum w/ Azdel.
WoodGlue
I'll quote myself because I think this post got lost!
Here is their webpage:
Camp Lite Trailers
WoodGlue - thomasmnileExplorer
MookieKat wrote:
Before I read this post, I had no idea what could go wrong with the light trailers. Now, I am paranoid about lightweight TTs. I feel like now I have to buy a heavy TT and buy a beast to haul it around to the tune of money down the drain on gas!
How many on this forum have had issues with delaminating or seams coming unglued in their lightweight TTs?
Mookie: What you're agonizing over can happen on ANY any laminated RV, regardless of weight or cost. Conversely, water intrusion into stick and tin won't result in delamination, but there's more wood that could sustain rot. However, it's easier to repair water damage in a stick n' tin. Bottom line, you have to be proactive with maintenance of the roof and all penetrations of the roof and sidewalls. Trailer type is a matter of personal preference; that's why manufacturers build both types.
What's irritating is when either construction type has leak issues straight from the factory............:M - coolbreeze01ExplorerHave you looked at Airstreams yet? Rivets vs welded can create a debate.
- beemerphile1ExplorerI have never ever read of anyone complaining about delamination with a stick-n-tin sided trailer. That is because it doesn't happen.
- LantleyNomad
PamfromVA wrote:
We had a 2007 Coachman TT fall apart on us. I think part of the problem is we use them for long road trips and most light TT's are made for the one weekend a month crowd. When we started looking for a replacement in a floor plan that we wanted, my first requirement was that it was able to carry at least 3,000 lbs. I believe those with the hightest capacity have the greatest chance of survival. As far as leaks, that's a crapshoot based on the mood of the workers who put your camper together that day. I've been on here long enough to read about $7K thru $150K campers with leaking problems when new. Keep a close eye on anything you buy for the first year and be diligent with preventative maintenance after that.
Good points Pam. I believe in the NCC net cargo capacity. rule as well. If the NCC is low I'm skeptical.
Nothing wrong with a stick and tin unit at all. There are plenty of 10+ years old plus models still going strong.
Smooth sided trailers are far from foolproof despite all the marketing and new fangled this and that propaganda that is meant to lead one to believe smooth sided trailer are the best thing since sliced bread.
I have a smooth side unit and so far I have had no issues however I know it has the potential for leaks and damage just liker any other RV. - PamfromVAExplorerWe had a 2007 Coachman TT fall apart on us. I think part of the problem is we use them for long road trips and most light TT's are made for the one weekend a month crowd. When we started looking for a replacement in a floor plan that we wanted, my first requirement was that it was able to carry at least 3,000 lbs. I believe those with the hightest capacity have the greatest chance of survival. As far as leaks, that's a crapshoot based on the mood of the workers who put your camper together that day. I've been on here long enough to read about $7K thru $150K campers with leaking problems when new. Keep a close eye on anything you buy for the first year and be diligent with preventative maintenance after that.
- certified106Explorer
I have even with proper maintenance but I had more issues with the cheap crappy flooring they put in them which utilizes the luan and styrofoam sandwhich system. I opted to go with stick and tin on my last to rigs and have been very pleased with them. I personally wouldn't worry about my light weight trailer falling apart if I owned one just keep up with the maintenance (as with any camper).
As to using more gas to haul a heavier camper around I'm sure it might use marginally more fuel but the frontal area of your camper has far more effect on fuel economy than the weight! I didn't even experience a 1 mpg decrease in fuel economy going from a 19 foot camper to a 30 foot camper and adding an additional 3,000 pounds in the upgrade. - MookieKatExplorer
Mike Up wrote:
MookieKat wrote:
WoodGlue wrote:
You're looking at a "Stick & Tin" trailer aka: Aluminum Siding!
WoodGlue
Is that good or bad?
LinkMike Up's Post wrote:
I stay away from lightweight travel trailers now that I have a real tow vehicle. I looked at about 5 different models and even had a deal fall through right before I signed the papers because it's shoddy lightweight build was actually falling apart on the dealers showroom! I didn't realize how bad it was until we did a walk through with everything operating. Lightweights use "GLUED" or "VACUUMED" Styrofoam around cold/hot conducting aluminum frames, onto thin substrates as luan or other eco 1/16" thin boards. That in turn is glued (or vacuumed) again to decorative board on the inside and the thin fiberglass/gelcoat sheet on the outside. Laminated sandwiched walls. NO THANK YOU.
Since I've been paying more attention to these types of campers, I've seen 2 out of 3 with delamination (wall came unglued).
Plus the aluminum framing is conductive to allow condensation on the walls on certain models. PLUS some models use the aluminum framing around the borders and only have a few internal braces for windows with no normal studs. Then you have aluminum welds which are known to be weak. Ladder makers use rivets for strength as a feature over aluminum welding.
Plus these lightweights have lighter material inside as well. Walls flex around more, cabinetry is lighter and weaker, and believe it or not, even the floors and/or roofs are laminated on some models including "JAYCO". NO WAY!
I recommend the tried and true Aluminum sided stick and tin. In fact many are made with the same studs and wall framing as large mobile homes. I have family with them and they have lasted decades if maintained. If you want a camper to last, these are the ones.
How many on this forum have had issues with delaminating or seams coming unglued in their lightweight TTs? - WoodGlueExplorer
Marsland wrote:
MookieKat,
Please take no offense to what I say, but respectfully, looking for the most ideal material, the best floorplan, and so forth is an impossible task. You will get people to agree and disagree on almost every question you ask.
As far as the "best" construction goes, how much money do you want to spend? That's probably the answer to that question.
There are literally probably millions of happy campers out there with dozens of different type materials and thousands of floor plans. To go out and for your first purchase find the exact match for you is shooting for the moon. It's most likely not going to happen.
Simply stated, there is no perfect RV, hence all the different options out there. Find one you think you can live with and jump into the pool. And be adaptable. Otherwise you'll undoubtedly be unhappy.
I've had, let me see, 11 different RV's over about 35 years, all types, mostly used, some new. Happy with all but one, old class C motor home, was really a piece of junk, my bad. We just enjoyed what we had. But they all have limitations. Size, weight, capacity's, comfort.
Don't get me wrong, there's nothing wrong with researching and learning. Just don't over think this. You'll wind up with no RV or unhappy with your choice.
Again, Respectfully submitted,
Richard
X2 on this! Very well stated Richard!
Just find out what fits in your budget. Look at a bunch of them and take the leap!
WoodGlue
44,056 PostsLatest Activity: Dec 27, 2025
