dodge_guy
Dec 30, 2014Explorer II
3oaks wrote:
If properly maintained to start with, bearings packed-not over greased and bearing castle nut correctly set, along with brakes adjusted correctly, about every 3 years. I started out with yearly inspection intervals, then 2 years without any issues found or concerns and now 3 years between thorough bearing inspections and grease seal changes. And we average about 2,000 miles per year towing our TT.
I do the same. About every 2-3 years depending on mileage. I do about 3-5k miles a year. I only had one issue with a grease seal that started to leak. Caught it just in time before it coated the brakes. I just services mine this spring and everything was good, that was a 3 year service.
