CKNSLS
Jan 02, 2015Explorer
jfkmk wrote:PapillonOne wrote:CKNSLS wrote:
That's one of the issues with repacking bearings. More often than not your better off just using the bearing buddy (if equipped)and leaving the bearings alone as far as dismantling everything IMHO. I can't count the number of posters who say they repack their bearings every year, every two years, etc., and when they take them out they really even didn't need repacking. I'm going the bearing buddy route and checking temps with an IR gun.
Could you provide more info or a link as to that the "bearing buddy" route is that you spoke of? And what is an IR gun and what does it do please. Thank you.
Janet
Janet,
Just do a quick search on bearing buddy and it'll take you right to their web site. The IR he's refering to is an infrared thermometer. You can "shoot" it at the hub and get an idea if one is running hotter than the other, indicating a potential bearing failure. These thermometers are now very cheap, especially at places like harbor freight.
Unfortunately, once the bearing starts to run hot, damage is already starting. If you're on the road, this could mean an expensive repair. Bearing maintenance, at least in my opinion, is preventive maintenance. In other word, do the maintenance before it is needed, not once a breakdown has begun.
Bearing maintenance, at least for even the most mildly mechanically inclined, is very basic and quite inexpensive, especially compared to a breakdown on the road. To each their own, but I'll invest a little time and a couple of dollars each spring to help ensure a trouble free camping season.
Repacking bearings is an EASY JOB in the sense that everything is basic. However, jacking up the trailer, pulling the bearings etc., is not an easy operation and it's even a messy affair and shouldn't be attempted by those who don't even change oils in their own vehicles. Once a year is overkill. For everyone on this forum that repacks their bearings annually, there are several that use the bearing buddys (or equivalent). There is no anecdotal evidence to suggest one way is better than the other.
