aftermath wrote:
I purchased a used Airstream and took it in to the local dealer to have them check the bearings and the brakes. I have done this on my 55 Chevy, 64 VW, 62 Chevy and 64 Ford PU. Not really all that complicated but I had no experience with the electric brakes on the trailer. Remember this is a dealer who seldom worries about charging high prices. I asked them how often I should have the bearings repacked and he said, every 10K miles. More often, unless you consider this a hobby isn't really needed.
As far as EZ Lube axles, I am not a fan. I think these are the improved version of Bearing Buddies that were designed for boat trailers. Do you back you trailer into the lake? No worries, just use our Bearing Buddies and you will be fine. We installed a zert to pack more grease so you will never run dry! IF, and I really mean If, you follow the recommendations and guidelines with your EZ lube setup you should be fine. I think more people than you think, just pack the bearings full and feel good about things.
EZ lube setup was an improvement over bearing buddies which was originally designed for use on boat trailers where the entire wheel along with brakes and bearings get submerged in water immediately after a drive on the road.
The sudden cold water dunk at the boat ramp causes the heated air, grease and even bearings inside the hub to contract, the contraction then pulls water from the river or lake right into the bearing space.. That water then degrades the grease and eventually rusts and damages the bearing surfaces..
The idea is if you fill the entire cavity with grease, then you arrest most of the reasons why water can get pulled in from the river or lake.
Bearing buddy only worked up to the point the grease seal could no longer hold back the grease and the extra grease ended up on your brakes.
EZ Lubes were simply adopted by trailer manufacturers for non boat trailer uses because of the appeal to the RV masses of "never ever needing to remove the drums".
RVs since you are not submerging the wheel and bearings in cold water bath are more about the marketing aspect to the lazy or less knowledgeable folks.
It is a sales gimmick on RVs.
The reality is you STILL have to eventually pull the drums to INSPECT the brake shoes and all moving parts inside the drum periodically. EZ lube does not negate the need to inspect and replace wear items like brake shoes or drums.
As I have mentioned I have a TT with standard axles and a flatbed with EZ Lube.. I personally have a hate for EZ Lube when it comes time to remove the drum.
In PA we have to take trailers of 3,001 lbs GVWR and higher in for a annual safety inspection. Inspection mechanic is required to pull one drum on each side at the inspection.
One yr I had a mechanic pump two cartridges of grease into the EZ lubes over two axles.. While I appreciated his thoughtfulness, I was in hate mode the next yr when I pulled the drums to check things before I took it in for inspection.. Took a dozen gloves and a complete roll of shop towels to clean out the excess grease and to prevent the unneeded grease from getting on the brakes or drum surfaces.
I like to be proactive and repair things before I drag a trailer for a 40 mile round trip for inspection.. Hate having a rejection then have to drag back home, fix and return..
Bearings properly hand packed only takes at most 1-2 ounces of grease per bearing, not the half cartridge of EZ lube per wheel..
