WayneAt63044
Jun 02, 2016Explorer II
Check with the manufacturer, if you can determine that. I contacted mine when upgrading from load range C to D (50 to 65 psi). Their limit was based on the valve stem so I changed from rubber to steel valve stems rated for the higher pressure.
44,070 PostsLatest Activity: Jul 11, 2026
