Huntindog
Dec 06, 2020Explorer
otrfun wrote:I will add, that a lot of people have no clue as how to properly setup a WD hitch to get the maximum benefit. This is obvious just observing rolling trainwrecks waiting to happen going down the highway..... And those that do not want to use a WD hitch just don't understand what they are missing.
IMO a lot of folks have handling/sway problems, don't bother (or don't know how) to check their tongue weight percentage, and purchase/use a WDH (and anti-sway) as a band-aid fix.
With 15% tongue weight (bumper-pull) you shouldn't have any handling/sway problems with any vehicle. Many 1/2-ton trucks must use a WDH to because of their limited rear axle capacity (which ends up off-loading weight from the front axle), not because they inherently need a WDH/anti-sway to prevent handling/sway issues.
We towed a 35', 10k bumper pull TT (with 14% tongue weight--1,400 lbs., and no WDH) with our '16 Ram 3500 SRW Cummins cross-country many times. Towed like a dream, even with 35 mph sidewinds. All you felt was one push/pull with every wind gust. When an 18-wheeler passed too close, again, just one push/pull, and that was it. Zero sway--completely stable.
The thing about towing setups is that there are many opinions on just what level of performance is acceptable to each individual.
I am anal about it. It starts with proper TW, Tire pressures etc, and ends with a properly setup WD hitch.... Because I do not settle for good enough,,,, I want it to be the best it can be. There have been a couple of times I was glad I was so particular.
It is a lot like seatbelts. One can drive millions of miles and not need them (does that make one a fool for using them?) or have a wreck going around the block.... and be glad you were using them.
