Buzzcut1's avatar
Buzzcut1
Nomad II
Dec 12, 2015
When the Norcold Fridge goes PERMAFROST
It started a week or so ago. The fridge started getting too cold. It was OK on Propane but on AC any setting above 2 sent the contents into the ice age. At 3 the fridge was at 28-32* and the freezer was at 0. The Model is N641.3 Per the Norcold trouble shooting blog it was either the Thermister or the Optical Control Board. I opted to replace the Thermister at $25 vs the optical board at $188 to see if it would fix the issue.
I ordered it on Wednesday and it arrived from Southern California tonight. It took 3 minutes to swap it out, no tools required. I set the fridge on AC and a temperature setting of 4. The temperature has been holding at 40 for 3 hours now. I am venturing that we have a solution.
Photo new part number bag and old removed Thermister assembly
link for ordering Norcold Parts
Norcold Parts ordering
  • Buzzcut1
    That thermistor S/B on the 10th fin from right for correct fin temp readings/thermostat control
    deltabravo
    The thermistor (Norcold/Dometic/Atwood) attaches to a fin in food compartment for temp sensing......the leads go thru fridge wall and plug into the control module located on backside of fridge in outside compartment
    Depending on which Brand determines which fin
  • I keep reading good things about this. I wonder if Snip The Tip would help in this situation.
    That Link is for the Domestic Models.
    There is one also for Norcold......LINK
    Easy way to replace a bad thermistor w/o having to pull thermistor leads thru fridge compartment wall to plug into control module...which one would have to do with an OEM replacement
    Except for models like OPs
    They plug/unplug right there at light assembly so OEM is easy replacement.
    I like the one I put in.Works perfect on the default setting.
