- in5rExplorerRockler.com has many different cabinet hardware items that may fit your needs.
- NEOKExplorerLook on eBay for the metal spring supports. I found several on there when I replaced one of mine.
- K_MacExplorerI got mine at CW , an exact match to what NL put in my 13" 10-2. Look at the ones in the kitchen area cabinets, that size worked fine for mine.
- hedgehopperExplorermarkchengr,
That sounds like it might be what I'm looking for. But the link doesn't work. Could you recheck it please? - markchengrExplorer III used these. They're the same as the ones Northern Lite uses on their overhead cabinets. They work great and you only need one for each door. Don't know why they didn't put them on there in the first place. -Mark.
http://www.rvdiscountsuppliers.com/hardware/cabinet-door-supports/cabinetdoor-spring-support-rv-camper-trailer-parts.html - Reddog1Explorer III have seen a simple spring used. One screw in each end for mounting. Mounts like the Camping World support. Because it is a spring, when the door is open, you simply push the center area of the spring in and it closes the door. The springs are about 3/8" to 1/2" in outside diameter. The come in different lengths and available at most hardware stores.
Wayne - bcbouyExplorertry craigslist.there's always someone scrapping a camper for parts.
- Golden_HVACExplorerhttp://www.liftsupportsdepot.com/
They have a very large selection of lifts. Yes even small ones and ones for my tailgate on a Dodge caravan.
Fred. - TripalotExplorerCamping World also carries some. We have to replace one on a cabinet over our kitchen sink. Check the length and the pressure carefully. The C.W. we were in did not have exactly what we needed so we are hopeful another location will. Cost was about $20.
- GeewizardExplorer
44,066 PostsLatest Activity: May 13, 2026
