path1ExplorerMay 12, 2019Where does the weight go to when using wd hitch?If tongue weight scale says 930 pds and then you hook up to to hitch ball and then load up wd spring bars...what happens? Where does that 930 pds go?
LwiddisNomad IIMay 13, 2019Bigger isn’t always better. If within a hitch limit...without WDH and with, you’re fine.
Related ContentBest Weight Distribution HitchActual Hitch Weight vs Dry Hitch WeightHitch weightWeight Distribution HitchDry tongue weight versus fully loaded
