OleManOleCan
May 13, 2019Explorer
path1 wrote:
If tongue weight scale says 930 pds and then you hook up to to hitch ball and then load up wd spring bars...what happens? Where does that 930 pds go?
The WD hitch transfers part of the weight forward to the front axle.
Properly set up the WD bars need a little lift to go on with some pressure.
If the bars go on to easy, it ain't set up correctly.
Equalizer has a pretty good video that explains it better than I can...
44,066 PostsLatest Activity: Apr 15, 2026
