Blanco1's avatar
Blanco1
Where is the best place to buy a used Trailer Dolly?
Looking for a USED Electric Trailer Dolly.
Being where I live & plan to store my trailer I'm not likely to get anything of a decent size if I have to back it in while connected to a truck.
( Part of why I'm not getting a 5th wheel )
I basically have a 90 degree turn I need to make & the neighbors fence is directly across from my driveway.
So whats the best way to enter a search for a used Electric tow dolly & where besides Craigslist would you recommend?
Once I clean the back yard of my current toys I'll go rent a 30 foot TT & try to back it in & see how much trouble it will be or if I might be able to go bigger or if I will have to go smaller?
I will NOT PAY for storing of the trailer.
  • George3037 wrote:
    Blanco1 wrote:
    George3037 wrote:
    Maybe one of these will work for you.
    electric trailer mover
    HA!
    I just noticed after posting the link I found that you basically posted the same one.
    I just wonder how does it stay balanced on just the 2 tires & now flop around?
    & wonder if it would make over the V shaped guid on the ground that my gate rides on?
    Thanks for the link.
    Overtons sells the manual crank one you posted. Just have to check the weight limit. Most manual crank ones are only good for 5K.
    Yeah that about what I figured & why I was thinking electric.
    HA!
    HA!
  • If you ARE looking for a "used" trailer dolly then CRAIGSLIST OR EBAY IS YOU BEST AND ONLY PLACES TO LOOK.
    Craigslist, you NEED to open up your search area by using the NEXT nearest locations listed, then move out a bit further, then further out and so on. It is how I find antique autos and parts.
    YES, it is a pain to have to MANUALLY SEARCH CL but that IS the "way it is done" there. Not to mention you are looking for an EXTREMELY expensive doodad that does only ONE JOB that nearly no one is willing to pop for them even used.
    So, if you can't find it used on CL or EBAY then it simply is not going to happen.
    If you really want one, you most likely WILL have to shell out the money for a NEW ONE.
    Personally, those things are not the safest things, most are only designed for FLAT TOWING AND ON PAVEMENT (cement, blacktop), most do not even have any brake control.. Yeah, some folk have bought em, doesn't mean they are a good idea.
    Consider having a hitch put on the FRONT of your tow vehicle, allows you to make extremely tight turns and you have the safety of the four wheels of your vehicle plus you could make an extension for the trailer plugin which would allow your vehicle to control the trailer brakes.
