bobbolotune's avatar
bobbolotune
Where to fill air in dually rear wheels?
Truck Camper Magazine just did a whole article about maintaining tire pressure in dually tires: Truck Camper Magazine dually tire pressure article
Lots of talk about equipment but I still don't know what to do...
I have no problem reaching both the inner and outer tire valve stems with a truck style dual chuck (that has a fitting both on the end to push onto the inner tire valve stem and an angled fitting to pull onto the outer tire where the valve step faces inward). So I have no need for valve extensions, especially after reading the Truck Camper Magazine article and the problems some people have with them I would rather skip that complication.
My problem is where to find air with the truck style dual chuck.
People say that this is available at truck stops. I have spent a lot of time at Pilot / Flying J truck stops. I have walked around and never figured out where the dual chuck air fill up is located. One Flying J had RV lanes with the correct fitting, but other than that the air fill ups in front are automotive style not truck style dual chuck.
My truck is gas so I have never gone through the diesel pumps in back. Maybe the air fill is at the diesel pumps?
If so I don't look forward to lining up with the trucks in my little truck camper and trying to fill 6 tires, doing this with two 18 wheelers lined up in back of me waiting for the pump.
So my question is, everyone says truck stops have the correct fitting. Where is the air fill up at say a Pilot that does not have RV lanes?
Is the air fill up free, that I just line up with the trucks and fill up. Or do I have to request it inside somehow.
I have only added air to the tires once since buying the truck. I was in northern Minnesota where there were no truck stops. My air was low so out of desperation I went to a Dodge dealer and the service manager was kind enough to pull an air hose out to the driveway for me (since the truck camper wouldn't fit in the garage). Now I am leaving on a trip and the air pressure is a little low again and I have never solved this problem of where to find air. There are Pilot truck stops on the way to where I am going but I have never located the truck style air fill up at a Pilot.
It seems another solution would be to get an air chuck adapter like this: adapter on amazon
Then from what I read get a 1/4" male to male adapter to screw into the bottom. Then it could be used with any standard gas station automotive air chuck. But I think it is going to be tricky to hold the air hose on the bottom of the adapter with one hand and the top of the adapter into the tire valve with the other hand. And that is if there is enough pressure at the automotive air fill for the higher psi of the truck tires.
Or another solution would be to buy a small compressor. I would like to be able to carry a small compressor in the truck that plugs into the cigar lighter. Some advertise up up to 150 psi so it should be able to fill the truck tire. However, I can't find one of these with the truck style dual chuck.
  • I think if you ask most folks here, you'll find that it's very rare to the point of being almost unheard of to have to add/tune your air on the road.
    If your tires are leaking to the point where you need air NOW and can't move on to the next service area or truck stop, you've got bad leaks that need to be fixed before you hit the road again.
    I've only needed to air up once on the road, and then it was a waste of time to try adding air because the valve stem had failed. While I don't remember exactly what kind of air chuck was on the pump at the gas station in the small town where I discovered the flat, I know I was able to get it in there and get it on the valve stem to find out that air was the last thing the tire needed.
    I would expect truck stops to have air available with the appropriate dually chuck where the trucks go. You will have to suck it up and mingle with the "big boys" if you are desperate for air. When in doubt, ask the cashier.
  • The air at fly J is indeed in the semi truck fuel lanes. I would go thru there with my gas class A and fill with water. You will not have a problem with your truck in there.
  • I do it in my driveway, using my big shop compressor. If you're needing to add air more often than once every several months you have a leak that should be attended to. I find I drop a few PSI over about six months, so twice a year suffices, primarily once in the late fall when the cold weather arrives. I don't worry about the difference between 75 and 80 psi, I doubt that my air gauge is anywhere close to that accurate.
    I've never see one one of those cigarette lighter compressors that wasn't useless. You could grow old waiting for it to pump up a truck tire.
  • Stop by a tire shop, most will top of the air in your tires at no charge. I do this with my dually as it's PITA to put air in them, never been turned away.
  • bobbolotune wrote:
    Or another solution would be to buy a small compressor. .
    This. But I wouldn't get anything that plugs into the cigarette lighter. You want something that you need to clamp secure to the battery terminals (or permanently mounted) and has a 100% duty cycle.
    Like this
